Radio shack road phantom 4wd: hobby conversion
on 2013-01-31 01:28:38 UTC
I converted this radio shack road phantom 4wd dual motor to a full hobby car and now it runs on 11.1v lipo. Stock it ran about 15mph on 7.2v but just off the conversion and 11.1v lipo it runs an easy 25mph+ and accelerates waaaay quicker. It's actually really fun to drive now that it has power and handles amazing for what it is. It used to struggle in grass and now it flies through tall grass.
Update: 550 12t motors are in and now it easily goes 40mph+++. Also went from 10 tooth pinions to 13 tooth and it definitely helps top speed
Electronics:
Vxl-3s esc
Fm radio
Traxxas 2070 servo
5400mah 11.1v lipo
Traxxas Titan 550 12t
Video: I was putting around for the first few mins and had a few full throttle passes towards the end. i can get pretty close to full throttle off the line but dont want to be too hard on the gears
http://i1214.photobucket.com/albums/cc484/4runnerhouse/A0834D24-2300-40A6-AFB8-275ABA1353E8-15502-0000101946A31106_zpsa99c6523.mp4
by Viper GTS on 2013-02-02 16:48:15 UTC
The 550s are mounted but the 10t pinions are too small so I've got 13t pinions to mount. Good news is it will pick up 25-30% more speed and will be less likely to strip out the gears
by Viper GTS on 2013-02-17 00:33:54 UTC
The 550 phantom is done and it hauls sooooo much ass!!! On 8.4v its faster than 11.1v on stock motors but on 11.1v with the 550s its crazy fast. It rockets to top speed and I would say it very easily does 40mph+++.
by Viper GTS on 2013-02-17 18:02:00 UTC
Just made a video at the baseball diamond
by stussels on 2013-02-18 00:32:00 UTC
wow, i need to talk to you about what components id need to do my junk up!  thats impressive performance there ;D
by Viper GTS on 2013-02-18 01:13:56 UTC
Yeah man let me know what you wanna work on, I love modifying the old cars to haul ass.
by stussels on 2013-02-21 04:13:20 UTC
pm'd
by kimsbored on 2013-04-10 17:47:20 UTC
Nice work with the conversion, do you have any more pics of how you used the larger pinions? and are they 48p?
by Viper GTS on 2013-04-12 03:07:42 UTC
I haven't taken any but I can tell you all I had to do was drill through the holes on the motor mount where it originally was used to mount to the transmission. The holes line right up with a 540/550 motor. When I drilled them at first I put a factory sized 10t pinion on and thought it was strange because it didn't even touch the spur gear even tho it was stock size. So I went with the biggest possible gear that i thought would still fit which was a 13t. The mesh was too tight so I opened up the mounting holes to shift the motor slightly outward and now the mesh is perfect.
Since the gears are 32 pitch they actually hold up well to full throttle punches
by moonchild61501 on 2013-06-02 18:38:36 UTC
I have a question for yuh, I just picked up a road phantom and it doesn't work. ive already tested the motors and they do work...seems the circuit boards fried. the only issues I have are 1-the AA terminals in the car are corroded and covered in acid, can that be replaced? 2-if the steering servo works, do I need to replace it? also wondering I have a 9.6v hummer (nikko) that is on its last leg sadly.....could I swap its electronics into the road phantom and use it that way if it worked?
sorry for the 20 questions but I just got into rc as a hobby, well more the hobby grade end of rc...nikko, tyco....well they don't make cool fast cars anymore. so on to the next best thing.
I know its not cost effective to throw in the ballpark of 300 to revamp a toy grade car, but from what I saw you had done to yours I think it worth it!!
by Viper GTS on 2013-06-10 03:35:44 UTC
After modifying loads of hobby cars for high speed runs, hill climbs, mud bogs etc I will tell you as cool as it is I actual enjoy modifying nikko, Tyco, new bright and radio shack cars more than the hobby cars. If you like your road phantom at all or the hummer I will say it is a ton of fun after modifying them and seeing them haul ass. The road phantom is a well capable car and with the conversion will spank a slash or stampede around a baseball diamond. The hummer is also a great one because they handle well and are light so they are fast with little power.
If you want to keep it stock just first try to clean the contacts with sand paper or a dremel disc. I personally would just convert it. It's really easy to setup a servo and just running any hobby esc will make it faster. You can always just run the stock motors on 8.4v which will fit. I ran mine on 11.1v until the stock motors started burning then converted to twin 12t titans. 8.4v with a hobby esc will make it run around 20mph
I just now got done converting a nikko trailblazer to a hobby car and it is now more fun to drive then it would of been years ago. I'm running 8.4v and a really old modified brush motor but it wheelies soo good I can carry a wheelie all the way down the street.
by moonchild61501 on 2013-06-12 17:00:49 UTC
thank you for answering my questions!! I tried asking a few of the hobbytowns in my area and ill say their customer service is quite lacking!!I would like to keep it as stock as possible for awhile, im not used to cars that go that fast...the fastest car I ever had was tycos 9.6v scorcher...but I also like to jump my cars and that car wasn't meant for that!! id eventually upgrade the motors. the biggest problem I have with the hummer is the the plastic piece that connects to the servo and wheels cracked years ago, and ive really not found anything that could replace it, so after a lot of trial and error I finally found a fix that's holding together after some pretty harsh bashing, a few cartwheels and its still good. Quiksteel really works when you reinforce it!!
if I go and buy an esc, do I need the 4 AA batteries? the whole esc/radio was shot... gotta go aftermarket with that. what would you suggest for a moderately low cost set up (radio, transmitter, esc, maybe servo?) you said any hobby esc would work, do you mean literally any? its a shame that I found it in such shape really, it doesn't look like it got used much. the tires and basically everything else is new. I think the previous owner drove into a lake or something from the water damage...
I really want to tell you that I really do appreciate the help you've offered me. its never easy being new to something (but not) having to ask the stupid questions lol. im hoping toget it running soon with a new paint job! ill defenitly have to post when its done!!
by Viper GTS on 2013-06-16 14:55:50 UTC
First off, no problem! I enjoy messing with the old nikko/RadioShack rc's and bringing them back to life. I can help you modify yours as much as you want. If you go to hobby town USA they won't have a clue how to get your car goin unless its a newer hobby car. I used to love the place back in the day but when it comes to real custom it all just flies over their heads.
Once you convert to any esc you won't need the 4aa's because it will run off whatever battery pack you use. The aa's were just used to power the servo but you won't be using that either. The best way to set up your car with hobby electronics without spending a shit load at a hobby shop is to buy them on eBay. You can either buy a car that's ready to run with nice electronics but has a bad chassis or such, then you can get it for cheap. Then just pull off the electronics to get your car going. Yes, ANY esc will work.
The only hard part on a hobby conversion can be when you setup the steering servo. Some cars you have to engineer the servo to mount right while others can be super easy and with a little cutting the servo will drop right in. Luckily the phantom is an easy swap. After figuring out how to mount the servo then you need to setup the servo arm so you can connect your steering. I'm currently running my stock steering arm just by using a tamiya servo arm mount and the radio shack arm and "C" sit right on top. It works great for minimal mods but with all my mods I really need to convert to hobby arm and run adjustable tie rods to tighten it up.
Is your hummer the 9.6v digital proportional? If so, every car I've had on that chassis has the same problem with the arm cracking and the wheels wanting to toe out really bad. I had the f150 version back in 99 and it did it because I took the front bumper off and hit a hard bump. I just got a 99 jeep version of that chassis and its got the same problem. I am goin to convert it to a hobby car real soon with 540 and will post that one too.
by moonchild61501 on 2013-06-17 20:29:32 UTC
i was actually probably use the setup you have for the servo, its pretty low cost, bout 20 bux so that's an easy one to get. I was hoping to keep the steering stock on it if possible, but with no idea what the servos actual condition is its just simler. thanks for the tip on the servo setup by the way!! I would have been pretty well lost without it!
the hummer isn't digital proportional, but nonetheless those front tires since its been back up and running....I keep having to tap it tight again, not that big a deal, takes maybe ten min start to finish. I am looking to get m4 1.5 inch bolts, nuts and washers, then I can just put a bit of locktite on it and be done!! but its still awesome having it running again, it can take a beating again. its like having a brand new steering arm!!
my wife has a newbright h3. ive never been a fan of newbright but its got fake front shocks!!! and is slow as hell. Im currently also attempting to figure out how to make the shocks useable, and putting a 380 in it, just for a little more power. im assuming I gotta go full hobby if I want to swap the motors? not sure if I want to take it that far but hey who knows!! look forward to seeing what else your working on!!
by Viper GTS on 2013-06-29 13:45:37 UTC
Is the h3 a 6.0v or 9.6v? I've got a silver 6.0v h3 with fake shocks that someone gave me and I'm gonna convert just for the sake of it. I might run an 11.1v till the electronics fry to see what it'll do. As far as shocks go, if its got moveable control arms then installing shocks is easy. If not its a bit of work to make suspension.
by moonchild61501 on 2013-07-01 15:40:25 UTC
its the 9.6v version..crappy battery pack. it seems like it could go quick if it had a little power but those damn fake shocks. I have an idea on how to make them work. the control arm, if you can call it that. is just connected to the body solidly so going to have to cut, drill and then it SHOULD (I hope) work.
by moonchild61501 on 2013-07-14 21:01:15 UTC
its the yellow 9.6v. its ok but it would be so much more fun if it could go faster and withstand jumping. its going to be pretty hard because there is really no A arm or control arm. im at a point now were if I do go ahead and cut it, it might make it junk. I know your a new bright fan from other blogs, at least old new bright. is it really worth the trouble you think? my wifes fine w it the way it is but I know shed have more fun going faster.
why would new bright make it with decoration shocks anyways? to me that's just stupid. maybe they just got lazy..
sorry its taking so long to post my phantom, I recently had a disc removed from my back and had the nerve channels opened so ive been outta work for awhile and just cant afford the damn parts!! but im hoping that within a month or so ill have it ready.
by moonchild61501 on 2013-07-14 21:16:11 UTC
totally forgot to ask you!!! when I go to get a controller for the phantom, does it need a digi prop controller. and could you recommend one? I looked on amazon and they really don't tell me much info on the quality of the controllers so any help you can offer would be great!
thanks for all the help!! I really appreciate it!
by UX0KAWZHm1 on 2013-07-16 20:57:37 UTC
Which may be generate income felt by Proenza Schouler together with Marc Jacobs earlier this 7 days, and that's precisely the sense I did this morning as soon as i experienced Marchesa's collecting dream-like frocks.. Bedecked by means of eye-catching designs together with alluring knobs these types of timepieces stay ahead of others.
Have a wonderful mentality what have got a wonderful working day!. In all of the those methods Made to order grip lovers can be regarded better for the purpose just by others. Opening up afternoon features a capital drink station on your inn so it is in fact feasible for these phones enjoy the will show at their site.
Lewis | Spoil Twenty third The year 2013 ( space ) Individuals usage window shades so as to add charisma and additionally glitter glue to their households. In preferred web stores, you can find a massive number of . You should consider asking any nuptial retail outlet asst just for guidance on what's top capacity $ 4  Discount HJX Green HELLO KITTY cute Hiding Hide & Seek Silicone Soft Case Cover for SAMSUNG Galaxy S3 /S III and type for you personally.
Because of beading and even silverwork towards material model, Camera altogether features a rich, generally untrained creativity billiards involving professional craftsmen, most of which are generally caught in this case. We've often experienced like I got different and My spouse and i continue to do in order to you may I suppose you might state that When i april on the combat of an numerous drum.
Generally utilized on very small crochet hook varieties and also knitting tiny needles. Allowing you to invariably choose to shift. In the event you continue to choose to have big shorts for your following that trip, I needed advise taking some inflatable hangers (for the way a number of major items you now have).
Your not speculated to accept the gear out from the store. I am going to try to conduct some smaller clementine oatmeal, far too, i generally stringed fat free popcorn. Just a few toggle clasps possess a damaged loop on $ 237  Discount "Black" - Kitty Style Bow Soft Silicone Case Cover For Samsung Galaxy S3 (Samsung Galaxy SIII / S III) i9300 , ** (CLEAR FRONT SCREEN PROTECTOR + DIAMOND EARPHONE DUST PLUG + DUST BAG) ** one a circular product, which inserts into the similar ring like an enormous catch plus eyeball closing..
Not long when, they are used to his / her 1st difficulty about incline and additionally dale found in Malibu. To be sure appropriate bond, roughen eliminate all the transfer earlier than sticking the bead conclusion for you to complete ones own work. Alternatively, you might be Strength Professional player or some other fluoropolymer, keep in mind that the following twine do not extention, so you want the stress such that there aren't research approximately globules nevertheless drop the right amount of for ones beadwork that should be h2o..
Never purchase your pliers through the home improvement store. Bracelets are one accessories that pulls particular attention quite simply without being far too deafening. Designs are made by means of chiselling, or maybe as a result of linking teeny some silver with the wished habit. All of these bins earn very good the right gifts for ones gentleman with everything.. $ 15  Discount One-Piece iPhone 4 or 4s Black Rubber Case Starry Hello Kitty Fan
by Viper GTS on 2013-08-08 23:32:55 UTC
Yes it does! Also make sure you get one where you can adjust all steering settings. You need to be able to limit the steering so it doesn't steer too far and break anything
by moonchild61501 on 2013-12-28 20:28:41 UTC
Finally got all the parts and they are installed, but heres the problem im having...I cant get the servo to work no matter what I do....
my setup has the vxl3s-flysky fs gt3b receiver/transmitter kit- traxxas 2070 servo
I have setup everything and it goes forward and backward. I can plug the servo into the receiver with the transmitter off, but as soon as I turn the transmitter on the esc and receiver shut off. ive adjusted the trim on the throttle and steering as traxxas and flysky recommend and nothing happens. I know the servo has power because right when I turn the receiver on the tires move.. anybody have any idea whats wrong?? I have tried plugging the servo into ch 2, thinking maybe ch1 is bad, I know ch2 works and no response from the servo at all..ive been waiting so long to get this running that im going nuts that it wont frickin turn!! could the servo be bad?? thanks in advance for any help out there!!
by Viper GTS on 2014-01-06 19:30:00 UTC
sound like the servo is bad. If you unplug the servo and the speed control operates fine, then thats an easy way to the servo is bad. My summit shuts off when I get a bad servo, its mostly from sinking it in water soo much. I would get a new servo and you should be good to go
by moonchild61501 on 2014-02-08 23:39:42 UTC
well after a year of waiting on parts, couple months playing with trim settings etc, I FINALLY took my phantom out, ran AWESOME, even one ICE. ran for a good 15 min. was driving up the driveway (freezing cold in my hands) and it hit a rough spot, and the whole left side tire, knuckle, idler arm, a arm and the steering shaft input. cant get parts so sorry to say its off to the trash. take care of that phantom man! I had a blast with it and even though I only got 15 min run time, the year of anticipation were very worth it!
by Viper GTS on 2014-02-11 05:50:16 UTC
He'll I've probably got all the parts to fix it, or you could score a roller on eBay for dirt
by moonchild61501 on 2014-02-12 17:41:54 UTC
I scored one on ebay for 70 bux!!! guy says the stock electronics still work...but the hell with it Im swapping!! I just hope the tranny teeth are in better shape than the busted one, it sounded like it was skipping teeth. if it is in better shape looks like im going to be greasing it up good!! since I haven't done this before, any tips? do I need to be careful when removing the motors so parts don't fall off or is it an easy unscrew, grease reassemble? i WILL be posting pics of it when shes done. i was having an issue with the the car, id run it and it would just shut off, adjusted the trim and it was fine, then the vxl3s had to be reprogrammed everytime i put a battery in it. read its a pretty common thing with the vxl3s. runs really well on 8.4 3300mah. cant wait to get her back together!! should be a week or so, the seller is on a week vacation so he wont be shipping it until the 15th or 17th. gave up on that new bright hummer by the way, the fake front suspension is going to be to difficult to turn into working suspension. thank you for checking back on list forum man!! you've really helped me out!! till next time!!
by moonchild61501 on 2014-04-28 21:30:43 UTC
phantom revived
by Viper GTS on 2014-06-01 14:33:05 UTC
Sweet! I need to run mine soon
