fixing tyco truck fast traxx and nikko shredder
on 2010-10-01 03:27:16 UTC
so here is my new fast traxx truck that while in transit the rear shock mount broke on the gear box. sad since it is such a small part but as we speak hopefully J.B. weld is doing its job. luckily they refunded me 20$ making this truck cost me a total of 48$ and some tenderlovingcare.  :)
This next one Is the fast traxx truck's enemy the Nikko Land Shredder. I recieved t...his knowing the engines weren't in the truck and that one tread was broken. It was said that it does work. so I put the engines back into the truck and just test it to see that it works. then to my surprise i find that the left side of the remote is non responsive. this wasn't listed though so I'm still waiting to see what the seller will do to correct this. So tonight I ripped the remote apart and fixed it!!!! Then also i patched the tread with staples and glue haha. take a look.
Before
After
Although you can't tell the light is on on the remote
by djdarkforces on 2010-10-01 17:33:54 UTC
is tha shredder any good
by czstycor/c on 2010-10-01 17:57:33 UTC
i don't know its been raining. but i think it will be like  the fast traxx in low gear about, maybe a tad faster not sure, i'll be able to tell by next week, i'm at the beach this weekend.
by SavedONE on 2010-10-01 18:42:00 UTC
-I had a Nikko Land Shark, (car version of Road Shredder), I liked it, w/2 speeds
on the radio, it was much easier to manuver precisely.  The land Shark wasn't
nearly as good outdoors, it didn't have the ground clearance or aggressiveness of
tread to get around, & for some reason, kept loosening screws out of the underside
of it, in the dirt/rough, (but I'd imagine that was a fluke of the one I had).
by czstycor/c on 2010-10-01 20:25:04 UTC
there haha, when you refer to the two speeds do you mean the low, then turbo?
by SavedONE on 2010-10-02 07:09:01 UTC
-yep, & only a 1 spd. gbx.
by performerrpm on 2010-10-02 08:51:28 UTC
hmm my land shark had the turbo function on the remote plus it had hi and lo on the gear box, even so i dont think it had as much get up as the tyco, although it was still pretty cool.
mine also had the screw loosening problem.
cz you should have bought that lot i sold on ebay awhile back that had that landshark in it, along with many others
by performerrpm on 2010-10-02 08:54:48 UTC
by the way, you have an extra set of traxx belts you wanna turn loose of, cz??
by czstycor/c on 2010-10-02 14:46:17 UTC
i should have bought those probably. and i might be will to let a set go for the right price.
by zvonedj on 2015-11-12 17:28:24 UTC
Hi guys..
Just wondering where to get new rubber treads for nikko shredder ?
I have one fully working but i lost belts .
by dragon on 2015-11-14 04:11:23 UTC
I'm not sure if it would be an exact fit or not, but I did come across this set of Tamiya tracks for $9.95 on jameco.com:
Tank Track and Wheel Set
The Track and Wheel Set offers three different lengths of tracks to choose from, allowing for a large degree of adjustability and creativity in design. Sprocket wheels, idler wheels, and road wheels have all been included. Can be used with a variety of Tamiya Construction and Robotics products.
Set Includes:
(2) 30 link track belts (about 7 1/2 inch long)
(4) 10-link belts (2 5/8 inch)
(4) 8-link belts (2 1/4 inch)
Specifications:
Manufacturer Part No.: 70100
Width is about 1/2 inch
Wheels: large about 32 mm (1.25") and small about 11 mm (0.43") diameter.
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=358299&catalogId=10001&CID=GOOG&gclid=Cj0KEQiAsZayBRCrioKRkYetvc0BEiQAI70-AyB-9Adq3nIzhIh0jUczuPI3qSIH0eC3GRjOWvriC00aAjoU8P8HAQ
