getting lipo battery and charger HELP!
by czstycor/c on 2011-01-10 05:37:25 UTC
SO I KINDA want to understand more hobby grade stuff, and rcboyz on ebay made me an invoice for a ac/dc lipo charger that was 65$ and then a 5000 mah 7.4v battery for 100!! is this as cheap as it gets????? help from someone who knows hobby grade?
by Viper GTS on 2011-01-10 07:45:35 UTC
No thats the highest but heres why.
It depends on the rating of the battery itself, if its a 60c then thats a fair deal if its a 20 or 40c then no way. The C rating is a measure of power output, more C more punch.
The charger must be a high end for that. You can get a good one for even just $40 that will do the job.
Remember also to get a balancer for the battery, its the little chip that plugs into the extra wire you see on all lipo batteries. This makes sure than the cells stay even when you charge them. If you dont balance them not only will you start getting less than normal power but you can kill the battery permanently.
Here look at this, should help a ton for pricing
http://shop.ebay.com/i.html?_nkw=7.4v+lipo+5000mah&_sacat=0&_odkw=7.4v+lipo&_osacat=0&_trksid=p3286.c0.m270.l1313
by czstycor/c on 2011-01-10 13:11:44 UTC
wow can't just plug it in and go haha of course now i need a balancer too. what are good brands for these batteries i can trust?
would i be able to use this in a sf traxx just curious? but i guess i cant cause they don't have tamiya connectors
found out it is a 35C battery
by Viper GTS on 2011-01-11 00:33:29 UTC
If your not familiar with lipos, the way they work is you get full power the entire time then at the end they die off. In order to properly run a lipo you need the speed control setup for lipo. All speed controls set up for lipo have an automatic cut off that way you dont run the battery all the way down. Reason being, if you run the battery all the way down it is permanently dead. But the good thing about lipos is that they dont just slowly loose charge after sitting for days like nimh nicd batteries and you make a ton more power and ton more run time.
by czstycor/c on 2011-01-11 04:15:19 UTC
yeah, these little buggies say they can run on a 7.4v lipo, but the lipo could only be maybe 2inces long if that to fit in the holder
do i need a different balancer for every different type of lipo battery?
by Viper GTS on 2011-01-11 22:57:12 UTC
No, one balancer will work for them all. You can find lipos in all different shapes to fit almost anything
by czstycor/c on 2011-01-11 23:44:32 UTC
hmm, ok well the batteries that came with these buggies are tiny 7.2v nimh batteries that last for about 3 minutes, so i want lipos. so you thing i should get the charger they recommended?
this is what they recommended---Sk-iMax B6AC+ Charger
is this a balancer/ what i need?
http://cgi.ebay.com/Great-Planes-ElectriFly-Equinox-LiPo-2-5-Cell-Balancer-/370472747525?pt=Radio_Control_Parts_Accessories&hash=item5641e58205
by czstycor/c on 2011-01-12 18:37:45 UTC
here is the charger they suggested
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370474440889&ssPageName=STRK:MEWAX:IT
