Comparison of Rear Axle
on 2009-02-28 21:52:33 UTC
Here are some pics of my grey Jet Hopper:
It looks like a new model given that the rear axle has got a differential. But it take 8 AA cells as the old model
The rear axle is a new design to me:
It has the big tyres as my Super Bandit and Super Jet Hopper but it has a completely different set of gears (you can compare the above picture with the picture below of the Super Jet Hopper rear axle):
In terms of speed, the Super Bandit and the Super Jet Hopper gear set is faster although they require longer time to get to the top speed.
Have any of you seen the rear axle as that of my grey one?? Has it got also a differential??
I would appreciate anyone able to shed any light on the matter.
thanks
by jeffescortlx on 2009-02-28 22:32:52 UTC
Did you swap the tires with a bandit? It does'nt have the normal thiner tire up front and spikes in the back.
The axle on your grey one is what I would consider normal. It's what I've seen on most of the 9.6 stuff. It's what my Bandit has, and it has no diff.
by chevyguyjay on 2009-02-28 22:44:53 UTC
i like it.  :) im going to post a new topic for videos. i need some wheels like that in the front of my hopper.
by SuperBandit on 2009-03-01 08:07:52 UTC
Hi Jeff,
No I didn't swap the tires. Both the grey and yellow rear axle sets got the big tires (similar to the bandit or super bandit).
If that is the standard rear axle of the bandit then the super bandit must be faster, right?
anyone compared the two??
by st5150 on 2009-03-17 07:09:08 UTC
Where did you get the  jet hopper?  I believe the jet  name was given  to tyco cars  sold in  Europe.
by bandit01 on 2009-03-17 10:13:33 UTC
iknow that some of the baja bandits have same axle and have diff.i have one and it has diff.if you spin one tire one way the other spins the other way.
