My project Yellow Bandit
on 2011-12-14 00:48:14 UTC
Alright guys check it out i've had this idea for awhile, but don't know where to start, i'm using a wild thing rear on a eliminator chasis, and a fast traxx body, now i need to know what electronics inside i need so all who have modified tyco's help me out.  i'd like it to do 30mph but i don't know if the stock motor could do that.
so what do i need?
by olds45512 on 2011-12-14 02:03:40 UTC
heres some pics of my modded eliminator , i used a futaba s3003 servo, axial ae1 speed control and a futaba receiver. i choose the the axial ae1 because its one of the only esc that let me use the stock 8 cell tyco pack and because its small as space is limited. the full size servo fit better than the micro servo i was planning to use. i took my time and did it right, the truck powers on with the stock switch and i left the antenna screwed on so the truck looks stock. i used the stock motor because the way it mounts is weird and an aftermarket motor wouldnt fit correctly and because the gears wont really take alot of motor. my truck will do about 25-30 in high gear and will do wheel stands from a dead stop in high gear but i dont run it much so i dont know how long the gears will last.
http://s1233.photobucket.com/albums/ff386/olds45512/modded%20tyco/
by czstycor/c on 2011-12-14 03:15:20 UTC
sweet, i want it to look something like this when i'm done, like a full sized outlaw. but i do have all those other bodies to choose form
by olds45512 on 2011-12-14 03:20:29 UTC
if you go to the parts store and pick up some buffing compound you can get most of the discoloration off that body. just rub it on with a rag and with a little elbow grease it should look good as new.
by czstycor/c on 2011-12-14 03:37:22 UTC
ahh thank you! i plan to put some kind of stickering on it once i figure out what to call it  wild thing bandit wild outlaw, something
by poptart on 2011-12-14 04:05:47 UTC
that's badass i love it !!!,,,i wonder what it would look like with the chrome windshield also??? since it complements the outlaw so well,,,,you've already got the chrome motor in the back,,first thing i thought of before i read your last post was bandit wild thing lol
by czstycor/c on 2011-12-14 04:23:14 UTC
here i put the chrome shield in off an extra body i have. i think it would need chrome rims then
i thought this looked cool
by poptart on 2011-12-14 04:28:46 UTC
yeah agreed the black looks better,,,,and wow now thats a bandit wild thing !!!!,,,they should have put that into production
by czstycor/c on 2011-12-14 04:32:28 UTC
i have wild thing bodies to rip the decals from, sadly only one has the spoiler with the large logo.
by fatboyfsx on 2011-12-14 05:15:20 UTC
Very cool project  8)
Any plan on how to attach the engine into the bed yet?
by czstycor/c on 2011-12-14 05:29:42 UTC
easy, this is a fast traxx body so it already has alittle hole where the light came out, so the plug on the engine can barely fit in there supersnug. then i'll cut a slit to make the latch click  into place like it does on the outlaw
by stan on 2011-12-14 05:36:25 UTC
30mph? are you going brushless?
by czstycor/c on 2011-12-14 05:40:24 UTC
nope stock motor, i want it to top out at 30. im good with 25
by fatboyfsx on 2011-12-14 06:55:43 UTC
Nice, I was hoping making a slit would be the only modification needed.
by czstycor/c on 2011-12-14 06:58:47 UTC
yeah i might rig the engine up to power lights
by czstycor/c on 2011-12-14 18:17:20 UTC
hey olds are these the parts?
http://www.ebay.com/itm/S3003-Servo-hpi-rc10-tc3-xxxt-Plane-NIB-Futaba-RC-/120825165610?pt=Radio_Control_Parts_Accessories&hash=item1c21bdb72a
http://www.ebay.com/itm/Axial-AE-1-Speed-Control-/320811540663?pt=Radio_Control_Parts_Accessories&hash=item4ab1dba0b7
and for reciever, could i use the one you should me for the tamtech ferrari?
http://www.hobbypartz.com/79p-gt3b-carradio-lcd.html
or just do this?
http://www.ebay.com/itm/Futaba-2PH-Magnum-Sport-AM-R152JE-2-S3003-Servos-/200688618690?pt=Radio_Control_Parts_Accessories&hash=item2eb9f94cc2
this is an am radio though
by olds45512 on 2011-12-14 21:58:49 UTC
All the parts you linked are correct. I would just use the radio gear your going to get for the tamtech, you should be able to buy a second receiver or since its cheap enough just buy a second system for the bandit. The 2.4 will be much better than the older style am and 2.4 has a real short antenna so it wont have to stick out of the body. What are you looking to have done on the outlaw for your brother?
by czstycor/c on 2011-12-15 02:16:34 UTC
i want it hobby grade,but to look stock, i don't know what battery you would use unless there is some tiny lipo that would fit in the original battery tray, i'd want it to be able out run a bandit, or stay with one. and with the engine on the back be a wheelie king
by olds45512 on 2011-12-15 02:19:41 UTC
im sure i can come up with something, as far as looking stock thats not a problem. just let me know when you wanna send it.
by czstycor/c on 2011-12-15 02:24:43 UTC
you could change out the motor if you want its just i wouldn't know what to put in there.
by olds45512 on 2011-12-15 02:55:55 UTC
i just tore my mini apart to see what im dealing with and modding yours wont be a problem.
by czstycor/c on 2011-12-15 03:02:45 UTC
i'll probably send it friday
by olds45512 on 2011-12-15 03:04:09 UTC
Cool sounds good, I will pm you my info.
by olds45512 on 2011-12-16 14:51:05 UTC
The only part im not sure about on my eliminator build is the servo horn which is the piece that screws to he servo that the tie rods hook to, after 18 years of building rc I have a huge stash of misc parts so I just used what I had laying around, I plan on takeing it off and going to the hobby store to match it up and buy a couple I will mail you one when I ge them.
by stan on 2011-12-21 02:25:59 UTC
I have a timya pistal remote if your interested in it
